SE Crash
SE Crash
SE Crash
Running a p4 1.8, i install and run SE normally but when i try to create a protrusion, and exit the 2D screen, SE produces a termination log, and terminates! Yet i can open pre-existing parts files and no problems, just with protrusions/rotations!
RE: SE Crash
What version and service pack of SE?
Have you tried calling tech support. They are your best source for these types of questions.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: SE Crash
Check your video card driver. Make sure it's OpenGL. Get the latest driver available for your card. Play with the troubleshooting settings under display properties - settings (from Windows desktop). And yes, check with SE tech support. They have likely seen this problem before if you're using a common video card.
RE: SE Crash
Here is the crash log that appears, ill check the video drivers etc. thanks for the help!
Solid Edge crash occurred on 9/15/2003 at 19:09:07.
Elapsed session time: 0:00:02:48
Exception code: 0xc0000005 (Access violation).
Attempted to read at 0x00000065.
Solid Edge version: 12.00.00.66
OS version: English Windows XP Service Pack 1.
Number processors: 1
Crash ID: {A381E93C-5CE6-42B6-AE36-E7FAB6DFADCA}
Sold-To ID:
Owner: Matthew
Company: MGEN
Critical
System DLL    Version
ntdll.dll    5.1.2600.1217
gdi32.dll    5.1.2600.1106
ole32.dll    5.1.2600.1243
comcat.dll    5.0.2600.1
user32.dll    5.1.2600.1134
shell32.dll    6.0.2800.1145
oleaut32.dll    3.50.5016.0
comdlg32.dll    6.0.2800.1106
comctl32.dll    6.0.2800.1106
opengl32.dll    5.1.2600.1106
kernel32.dll    5.1.2600.1106
mfc42.dll    6.0.8665.0
msvcrt.dll    7.0.2600.1106
Most recent command: 0x3f6588b9 CmdExe  cmdId = 45018 cmdEnv = "Part" cmdTip = "Revolved Protrusion"
Most recent events: 30 of 32
Ord Time       Event   Data
 00 0x3f658838 DocCtor docNum = 0x09bf1008 docNam = "Untitled"
 01 0x3f65883c DocChg  docNumAct = 0x09bf1008 docNumDeact = 0x00000000 docNamAct = "Part1" docNamDeact = ""
 02 0x3f658842 EnvChg  envAct = "Part" envDeact = ""
 03 0x3f658843 CmdExe  cmdId = 45002 cmdEnv = "Part" cmdTip = "Protrusion"
 04 0x3f658845 DocCre  docNum = 0x09bf1008 docNam = "Part1"
 05 0x3f658847 CmdExe  cmdId = 0 cmdEnv = "Part" cmdTip = ""
 06 0x3f658847 CmdExe  cmdId = 0 cmdEnv = "Part" cmdTip = ""
 07 0x3f658856 CmdExe  cmdId = 45000 cmdEnv = "Part" cmdTip = "Select Tool"
 08 0x3f658858 CmdExe  cmdId = 45018 cmdEnv = "Part" cmdTip = "Revolved Protrusion"
 09 0x3f65885c EnvChg  envAct = "ProfileRevolved" envDeact = "Part"
 10 0x3f65885c CmdExe  cmdId = 25010 cmdEnv = "ProfileRevolved" cmdTip = "Line"
 11 0x3f658861 CmdExe  cmdId = 25011 cmdEnv = "ProfileRevolved" cmdTip = "Circle by Center"
 12 0x3f65886f CmdExe  cmdId = 57643 cmdEnv = "ProfileRevolved" cmdTip = "Undo"
 13 0x3f658871 CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 14 0x3f658874 CmdExe  cmdId = 25011 cmdEnv = "ProfileRevolved" cmdTip = "Circle by Center"
 15 0x3f658880 CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 16 0x3f658882 CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 17 0x3f658884 CmdExe  cmdId = 25011 cmdEnv = "ProfileRevolved" cmdTip = "Circle by Center"
 18 0x3f658889 CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 19 0x3f65889a CmdExe  cmdId = 25003 cmdEnv = "ProfileRevolved" cmdTip = "Axis of Revolution"
 20 0x3f65889c CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 21 0x3f6588a0 CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 22 0x3f6588a2 CmdExe  cmdId = 25003 cmdEnv = "ProfileRevolved" cmdTip = "Axis of Revolution"
 23 0x3f6588a6 CmdExe  cmdId = 25003 cmdEnv = "ProfileRevolved" cmdTip = "Axis of Revolution"
 24 0x3f6588a9 CmdExe  cmdId = 25003 cmdEnv = "ProfileRevolved" cmdTip = "Axis of Revolution"
 25 0x3f6588a9 CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 26 0x3f6588a9 CmdExe  cmdId = 25003 cmdEnv = "ProfileRevolved" cmdTip = "Axis of Revolution"
 27 0x3f6588ad CmdExe  cmdId = 45000 cmdEnv = "ProfileRevolved" cmdTip = "Select Tool"
 28 0x3f6588b7 EnvChg  envAct = "Part" envDeact = "ProfileRevolved"
 29 0x3f6588b9 CmdExe  cmdId = 45018 cmdEnv = "Part" cmdTip = "Revolved Protrusion"
Global memory utilization:
Total phys: 223.48 MB  Avail phys: 32.46 MB
Total pg file: 547.1 MB  Avail pg file: 376.98 MB
Total virt: 1.99 GB  Avail virt: 1.69 GB
Percent phys used: 85
Process memory utilization:
Reserved: 94.97 MB  Committed: 218.98 MB  Free: 1.69 GB  Largest Free: 791.6 MB  Free Blocks: 402
Loaded modules:
(0x01270000 - 0x01278000) jutil.drx        12.0.0.65
(0x013d0000 - 0x013e4000) RFMSSVS.drx        12.0.0.65
(0x013f0000 - 0x0141a000) jdocres.drx        12.0.0.65
(0x01420000 - 0x01426000) JDIRSEL.drx        12.0.0.65
(0x01430000 - 0x01433000) umacro.drx        12.0.0.65
(0x01440000 - 0x01454000) cntlrc.drx        12.0.0.65
(0x01460000 - 0x0146d000) RFMSDCX.drx        12.0.0.65
(0x01470000 - 0x01474000) ChangeLog.drx        12.0.0.65
(0x014c0000 - 0x014c9000) engine.drx        12.0.0.65
(0x015d0000 - 0x0186b000) separt.drx        12.0.0.65
(0x02ca0000 - 0x04323000) PSKERNEL.dll        0.14.0.133
(0x04330000 - 0x04594000) Visual.dll        12.0.0.65
(0x045a0000 - 0x0461f000) libmmd.dll        <unknown>
(0x088a0000 - 0x0899b000) psbodyshop.dll        0.4.1.96
(0x089a0000 - 0x089b0000) MSVCIRT.dll        7.0.2600.0
(0x089b0000 - 0x08a10000) partPS.dll        11.0.0.10
(0x08a10000 - 0x08a13000) OLEDMUI.drx        12.0.0.65
(0x08a20000 - 0x08a23000) olesite.drx        12.0.0.65
(0x08a30000 - 0x08a37000) EdgeBar.drx        12.0.0.65
(0x08a40000 - 0x08a43000) copy.drx        12.0.0.65
(0x08a50000 - 0x08a53000) shlyhp.drx        12.0.0.65
(0x08a60000 - 0x08a63000) jfilsup.drx        12.0.0.65
(0x08a70000 - 0x08a73000) GRPMGRRC.drx        12.0.0.65
(0x08a80000 - 0x08a83000) DOCEXTRC.DRX        12.0.0.65
(0x08a90000 - 0x08ae0000) 2D.DRX        12.0.0.65
(0x08ae0000 - 0x08ae6000) expr.drx        12.0.0.65
(0x08b00000 - 0x08b04000) CNSTRBMP.DRX        12.0.0.65
(0x08b10000 - 0x08b14000) csymdlg.drx        12.0.0.65
(0x08b20000 - 0x08b23000) DRGNDRP.drx        12.0.0.65
(0x08b30000 - 0x08b42000) 2DLC.drx        12.0.0.65
(0x08b50000 - 0x08b64000) 2DSC.drx        12.0.0.65
(0x08b70000 - 0x08b81000) 2DLM.drx        12.0.0.65
(0x08b90000 - 0x08b9c000) 2DSM.drx        12.0.0.65
(0x08ba0000 - 0x08bc7000) STDDLL.drx        12.0.0.65
(0x08bd0000 - 0x08c5d000) STDPART.drx        12.0.0.65
(0x08c60000 - 0x08cc7000) PDCXBMP.drx        12.0.0.65
(0x08cd0000 - 0x08d06000) STDPARTBitmaps.drx        12.0.0.65
(0x08d10000 - 0x08d59000) SMTLCMD.drx        12.0.0.65
(0x08d60000 - 0x08d68000) WELDCMD.drx        12.0.0.65
(0x08d70000 - 0x08dcd000) SEPARTLC.drx        12.0.0.65
(0x08dd0000 - 0x08dfb000) SEPARTSC.drx        12.0.0.65
(0x08e00000 - 0x08e0e000) SEPARTLM.drx        12.0.0.65
(0x08e10000 - 0x08e18000) SEPARTSM.drx        12.0.0.65
(0x093e0000 - 0x099cb000) AEASM.DEX        12.0.0.65
(0x099d0000 - 0x09b6f000) asm.drx        12.0.0.65
(0x09b70000 - 0x09b79000) studio.drx        12.0.0.65
(0x09d80000 - 0x0a0b0000) detail.drx        12.0.0.65
(0x0a0b0000 - 0x0a0b3000) DraftRc.DRX        12.0.0.65
(0x0a6f0000 - 0x0a6f7000) GaugeMgr.drx        12.0.0.65
(0x0aa70000 - 0x0aa73000) styles.drx        12.0.0.65
(0x0aa80000 - 0x0aa83000) PROFDAP.drx        12.0.0.65
(0x0aaa0000 - 0x0ab9e000) sisgl.dll        6.13.10.2072
(0x0b060000 - 0x0b06f000) MOUDL32A.DLL        3.0.2.0
(0x0b290000 - 0x0b2ba000) PSHRDCX.drx        12.0.0.65
(0x0c350000 - 0x0c366000) PROFCMD.drx        12.0.0.65
(0x0c370000 - 0x0c3e3000) profile.drx        12.0.0.65
(0x0c3f0000 - 0x0c3fe000) vwstyle.drx        12.0.0.65
(0x0c680000 - 0x0c698000) VWCMDS.drx        12.0.0.65
(0x10000000 - 0x1000c000) Edge.exe        12.0.0.65
(0x1f7b0000 - 0x1f7e1000) ODBC32.dll        3.520.9030.0
(0x1f850000 - 0x1f866000) odbcint.dll        3.520.7713.0
(0x51000000 - 0x5104d000) DDRAW.dll        5.3.0.900
(0x55900000 - 0x55961000) MSVCP60.dll        6.0.8972.0
(0x5ad70000 - 0x5ada4000) uxtheme.dll        6.0.2800.1106
(0x5b0a0000 - 0x5b0a7000) umdmxfrm.dll        5.1.2600.0
(0x5cd70000 - 0x5cd77000) serwvdrv.dll        5.1.2600.0
(0x5ed00000 - 0x5edc6000) OPENGL32.dll        5.1.2600.1106
(0x5edd0000 - 0x5edea000) OLEPRO32.DLL        5.0.5014.0
(0x60000000 - 0x600ea000) JUTIL.dll        12.0.0.65
(0x60100000 - 0x60130000) ASM.DNX        12.0.0.65
(0x60140000 - 0x6018f000) separt.dnx        12.0.0.65
(0x60200000 - 0x6022b000) DETAIL.dnx        12.0.0.65
(0x60240000 - 0x6028a000) sestartup.dll        12.0.0.65
(0x60330000 - 0x603e4000) DOCMGMT.DLL        12.0.0.65
(0x604a0000 - 0x604ba000) GenLink.dll        12.0.0.65
(0x60530000 - 0x60568000) jdchlp.dll        12.0.0.65
(0x60570000 - 0x6079d000) jengine.dll        12.0.0.65
(0x607a0000 - 0x607c4000) LINKOLE.dll        12.0.0.65
(0x607d0000 - 0x607dd000) ltqry.dll        12.0.0.65
(0x60810000 - 0x608dc000) OLESITE.dll        12.0.0.65
(0x60950000 - 0x60974000) Seprop.dll        12.0.0.65
(0x60a80000 - 0x60b07000) AddInlm.dll        12.0.0.65
(0x60b10000 - 0x60b1a000) ChangeLog.dll        12.0.0.65
(0x60b20000 - 0x60b2f000) config.dll        12.0.0.65
(0x60b30000 - 0x60bcc000) control.dll        12.0.0.65
(0x60c80000 - 0x60c90000) Frustrm.dll        12.0.0.65
(0x60cb0000 - 0x60cbc000) jdirsel.dll        12.0.0.65
(0x61040000 - 0x61046000) log.dll        12.0.0.65
(0x610f0000 - 0x610f8000) OLEDMUI.dll        12.0.0.65
(0x61100000 - 0x61125000) ProbeUtilities.dll        12.0.0.65
(0x611c0000 - 0x611d8000) RFMSClientSideUtls.dll        12.0.0.65
(0x611e0000 - 0x61270000) RFMSDCX.dll        12.0.0.65
(0x61270000 - 0x61442000) RFMSsvs.dll        12.0.0.65
(0x61500000 - 0x61509000) taglist.dll        12.0.0.65
(0x61510000 - 0x61517000) timeutl.dll        12.0.0.65
(0x61520000 - 0x61620000) ubspm2d.dll        12.0.0.65
(0x61720000 - 0x61828000) ubspm3d.dll        12.0.0.65
(0x61940000 - 0x619ba000) ugeom.dll        12.0.0.65
(0x619c0000 - 0x61a26000) ugeom2d.dll        12.0.0.65
(0x61b20000 - 0x61b3c000) ugsm.dll        12.0.0.65
(0x61b40000 - 0x61b49000) umacro.dll        12.0.0.65
(0x61b60000 - 0x61b7c000) umath.dll        12.0.0.65
(0x61ba0000 - 0x61bab000) upstgt.dll        12.0.0.65
(0x61bb0000 - 0x61bb6000) uwmath.dll        12.0.0.65
(0x61bd0000 - 0x61c7c000) pvdt80.ocx        8.0.0.1
(0x61e30000 - 0x61e9b000) COREVW.DVX        12.0.0.65
(0x61ea0000 - 0x61edb000) EXPRDVX.DVX        12.0.0.65
(0x61f00000 - 0x61f3c000) VIEW.DVX        12.0.0.65
(0x61f80000 - 0x61fa3000) asmds.dll        12.0.0.65
(0x61fe0000 - 0x61fea000) avwsdlg.dll        12.0.0.65
(0x62010000 - 0x6201e000) bindex.dll        12.0.0.65
(0x62020000 - 0x62029000) bitarry.dll        12.0.0.65
(0x62030000 - 0x62047000) cmdspt.dll        12.0.0.65
(0x62080000 - 0x62091000) D3DGLST.DLL        12.0.0.65
(0x620a0000 - 0x620b8000) Daxutil.dll        12.0.0.65
(0x620c0000 - 0x620e3000) DBATCH.DLL        12.0.0.65
(0x620f0000 - 0x62108000) drgndrp.dll        12.0.0.65
(0x62110000 - 0x6212f000) EdgeBar.dll        12.0.0.65
(0x62150000 - 0x6217a000) EXPRDEX.DLL        12.0.0.65
(0x621b0000 - 0x621de000) fontmgr.dll        12.0.0.65
(0x621e0000 - 0x62216000) GAUGMGR.DLL        12.0.0.65
(0x62520000 - 0x6267c000) i9cflc01.dll        2.3.0.11
(0x627e0000 - 0x627ec000) idsapi.dll        12.0.0.65
(0x62930000 - 0x6294d000) liteidsapi.dll        12.0.0.65
(0x629b0000 - 0x62b7b000) MINIEMS.DLL        1.0.0.1
(0x62bc0000 - 0x62bf0000) PSCVT.DLL        12.0.0.65
(0x62c30000 - 0x62e80000) RENDER.DLL        12.0.0.65
(0x630d0000 - 0x63128000) RENDEX.DLL        12.0.0.65
(0x63320000 - 0x63341000) sensor.dll        12.0.0.65
(0x63360000 - 0x63370000) sexpk.dll        12.0.0.65
(0x63380000 - 0x6338f000) stylspt.dll        12.0.0.65
(0x633b0000 - 0x633ba000) Uprfhlp.dll        12.0.0.65
(0x637a0000 - 0x63812000) vwsedlg.dll        12.0.0.65
(0x638c0000 - 0x638db000) HSTYL3D.DAX        12.0.0.65
(0x638e0000 - 0x638f4000) HVWSTYL.DAX        12.0.0.65
(0x63940000 - 0x63958000) STYLES.DAX        12.0.0.65
(0x639a0000 - 0x639b5000) copy.dcx        12.0.0.65
(0x63ab0000 - 0x63ae1000) studio.dcx        12.0.0.65
(0x63b10000 - 0x63ba6000) VWCMDS.DCX        12.0.0.65
(0x63bb0000 - 0x63bdb000) VWSCMDS.DCX        12.0.0.65
(0x63be0000 - 0x63be7000) FSOVER.DEX        12.0.0.65
(0x63bf0000 - 0x63c0c000) grp_dex.dex        12.0.0.65
(0x63c10000 - 0x63c9e000) jgeom3d.dex        12.0.0.65
(0x63cc0000 - 0x63cd2000) lyrmgr.dex        12.0.0.65
(0x63ce0000 - 0x63ced000) NAMEDVW.DEX        12.0.0.65
(0x63cf0000 - 0x63cfd000) NAMEMGR.DEX        12.0.0.65
(0x63d00000 - 0x63d41000) STYLE.DEX        12.0.0.65
(0x63d50000 - 0x63d70000) STYLE3D.DEX        12.0.0.65
(0x63d70000 - 0x63d88000) stylmgr.dex        12.0.0.65
(0x63da0000 - 0x63df5000) symbol.dex        12.0.0.65
(0x63e00000 - 0x63e1c000) VWSTYLE.DEX        12.0.0.65
(0x63e30000 - 0x63e39000) ssymbol.dsx        12.0.0.65
(0x63e90000 - 0x63e96000) AutoUtils.dll        12.0.0.65
(0x63ee0000 - 0x63f54000) FWKAUTO.DLL        12.0.0.65
(0x64070000 - 0x64076000) cnstbmp.dll        12.0.0.65
(0x64080000 - 0x642d1000) DCM_IMP.dll        12.0.0.65
(0x642e0000 - 0x6433d000) hcnstr.dll        12.0.0.65
(0x64340000 - 0x64355000) hslvr.dll        12.0.0.65
(0x64360000 - 0x64375000) JFILSUP.dll        12.0.0.65
(0x643a0000 - 0x643b2000) shake.dll        12.0.0.65
(0x643c0000 - 0x643cd000) shlyhp.dll        12.0.0.65
(0x64410000 - 0x64438000) skpref.dll        12.0.0.65
(0x64440000 - 0x64463000) SMART.dll        12.0.0.65
(0x64540000 - 0x6454e000) vhlsupp.dll        12.0.0.65
(0x64550000 - 0x6455e000) XProbeUtilities.dll        12.0.0.65
(0x64560000 - 0x64583000) CNSTR2D.DAX        12.0.0.65
(0x64650000 - 0x64778000) GEOM2D.DAX        12.0.0.65
(0x64780000 - 0x647a8000) group.dax        12.0.0.65
(0x647b0000 - 0x648ae000) HANNOT.DAX        12.0.0.65
(0x64940000 - 0x6494e000) cmdactv.dcx        12.0.0.65
(0x64950000 - 0x64f92000) i2d.dcx        12.0.0.65
(0x64fc0000 - 0x6526b000) ANNOT.DEX        12.0.0.65
(0x65270000 - 0x652c1000) DOCEXT.DEX        12.0.0.65
(0x652d0000 - 0x654a1000) GRAPH2D.dex        12.0.0.65
(0x654b0000 - 0x654c8000) Grpmgr.dex        12.0.0.65
(0x654d0000 - 0x654e4000) jtopvfs.dex        12.0.0.65
(0x656f0000 - 0x6571b000) jmcmddcx.dll        12.0.0.65
(0x65720000 - 0x65745000) LITPRT.dll        12.0.0.66
(0x65780000 - 0x65795000) LITPSUP.dll        12.0.0.65
(0x65810000 - 0x65b2a000) partbrp.dll        12.0.0.65
(0x65b30000 - 0x65e43000) partDax.dll        12.0.0.66
(0x65e50000 - 0x662e5000) partDcx.dll        12.0.0.65
(0x662f0000 - 0x66573000) partDex.dll        12.0.0.66
(0x66580000 - 0x6659e000) PARTDVX.DLL        12.0.0.65
(0x665a0000 - 0x66698000) partmnk.dll        12.0.0.65
(0x666a0000 - 0x6699a000) partSvc.dll        12.0.0.65
(0x669a0000 - 0x66a46000) partutl.dll        12.0.0.65
(0x66a50000 - 0x66ad9000) PROFDAX.DLL        12.0.0.65
(0x66ae0000 - 0x66be7000) profdcx.dll        12.0.0.65
(0x66bf0000 - 0x66ce2000) profdex.dll        12.0.0.65
(0x66cf0000 - 0x66d2d000) profhlp.dll        12.0.0.65
(0x66d30000 - 0x66d55000) PRTDAT.dll        12.0.0.65
(0x66d60000 - 0x66d73000) ptrnsup.dll        12.0.0.65
(0x67620000 - 0x67859000) smtlbrp.dll        12.0.0.65
(0x67860000 - 0x6790c000) smtldcx.dll        12.0.0.65
(0x67910000 - 0x67958000) sprfhlp.dll        12.0.0.65
(0x67960000 - 0x679b6000) welddcx.dll        12.0.0.65
(0x679c0000 - 0x679f2000) Profile.dnx        12.0.0.65
(0x67a20000 - 0x67a2e000) DOCXSH.DLL        12.0.0.65
(0x67da0000 - 0x67f15000) PSHRDCX.DLL        12.0.0.65
(0x67fe0000 - 0x680b6000) acmdutl.dll        12.0.0.65
(0x680f0000 - 0x6812c000) asmapp.dll        12.0.0.65
(0x68250000 - 0x6828c000) autools.dll        12.0.0.65
(0x68290000 - 0x682ab000) cnfgutl.dll        12.0.0.65
(0x682b0000 - 0x682d4000) familya.dll        12.0.0.65
(0x682e0000 - 0x682e7000) famsvcs.dll        12.0.0.65
(0x68340000 - 0x6838f000) tubing.dll        12.0.0.65
(0x68b20000 - 0x68b3e000) GLU32.dll        5.1.2600.0
(0x69000000 - 0x690f5000) dethook.dll        12.0.0.65
(0x69f40000 - 0x69fb7000) EMS2SE.DLL        12.0.0.65
(0x69ff0000 - 0x6a001000) emstrns.dll        12.0.0.65
(0x6a1b0000 - 0x6a208000) JDVSvcs.dll        12.0.0.65
(0x6a550000 - 0x6a66e000) hdrvw.dax        12.0.0.65
(0x6d510000 - 0x6d58d000) DBGHELP.dll        5.1.2600.1106
(0x70a70000 - 0x70ad4000) SHLWAPI.dll        6.0.2800.1106
(0x71950000 - 0x71a34000) COMCTL32.dll        6.0.2800.1106
(0x71b20000 - 0x71b31000) MPR.dll        5.1.2600.0
(0x71bf0000 - 0x71c01000) SAMLIB.dll        5.1.2600.1106
(0x71c10000 - 0x71c1d000) ntlanman.dll        5.1.2600.1106
(0x71c20000 - 0x71c6e000) NETAPI32.dll        5.1.2600.1106
(0x71c80000 - 0x71c86000) NETRAP.dll        5.1.2600.0
(0x71c90000 - 0x71ccc000) NETUI1.dll        5.1.2600.0
(0x71cd0000 - 0x71ce6000) NETUI0.dll        5.1.2600.0
(0x73000000 - 0x73023000) WINSPOOL.DRV        5.1.2600.1106
(0x73b50000 - 0x73b65000) AVIFIL32.dll        5.1.2600.1106
(0x73bc0000 - 0x73bc6000) DCIMAN32.dll        5.1.2600.0
(0x73bd0000 - 0x73bf0000) MSVFW32.dll        5.1.2600.1106
(0x73dd0000 - 0x73ec2000) MFC42.DLL        6.0.8665.0
(0x74d30000 - 0x74d50000) oledlg.dll        5.1.2600.0
(0x75970000 - 0x75a61000) MSGINA.dll        5.1.2600.1106
(0x75a70000 - 0x75b15000) USERENV.dll        5.1.2600.1106
(0x75e90000 - 0x75f37000) SXS.DLL        5.1.2600.1106
(0x75f40000 - 0x75f5f000) appHelp.dll        5.1.2600.1106
(0x75f60000 - 0x75f66000) drprov.dll        5.1.2600.0
(0x75f70000 - 0x75f79000) davclnt.dll        5.1.2600.0
(0x76200000 - 0x76298000) WININET.dll        6.0.2800.1106
(0x762a0000 - 0x762af000) MSASN1.dll        5.1.2600.0
(0x762c0000 - 0x76348000) CRYPT32.dll        5.131.2600.1123
(0x76360000 - 0x7636f000) WINSTA.dll        5.1.2600.1106
(0x76390000 - 0x763ac000) IMM32.dll        5.1.2600.1106
(0x763b0000 - 0x763f5000) comdlg32.dll        6.0.2800.1106
(0x76400000 - 0x76601000) Msi.dll        2.0.2600.1106
(0x76670000 - 0x76757000) SETUPAPI.dll        5.1.2600.1106
(0x76980000 - 0x76987000) LINKINFO.dll        5.1.2600.0
(0x76990000 - 0x769b4000) ntshrui.dll        5.1.2600.1106
(0x76b20000 - 0x76b35000) ATL.DLL        3.0.9435.0
(0x76b40000 - 0x76b6c000) WINMM.dll        5.1.2600.1106
(0x76c90000 - 0x76cb2000) IMAGEHLP.dll        5.1.2600.1106
(0x76f90000 - 0x76fa0000) Secur32.dll        5.1.2600.1106
(0x76fd0000 - 0x77048000) CLBCATQ.DLL        2001.12.4414.42
(0x77050000 - 0x77115000) COMRes.dll        2001.12.4414.42
(0x77120000 - 0x771ab000) OLEAUT32.dll        3.50.5016.0
(0x771b0000 - 0x772c7000) ole32.dll        5.1.2600.1243
(0x773d0000 - 0x77bc2000) SHELL32.dll        6.0.2800.1145
(0x77be0000 - 0x77bf4000) MSACM32.dll        5.1.2600.0
(0x77c00000 - 0x77c07000) VERSION.dll        5.1.2600.0
(0x77c10000 - 0x77c63000) MSVCRT.dll        7.0.2600.1106
(0x77c70000 - 0x77cb0000) GDI32.dll        5.1.2600.1106
(0x77d40000 - 0x77dc6000) USER32.dll        5.1.2600.1134
(0x77dd0000 - 0x77e5d000) ADVAPI32.dll        5.1.2600.1106
(0x77e60000 - 0x77f46000) kernel32.dll        5.1.2600.1106
(0x77f50000 - 0x77ff7000) ntdll.dll        5.1.2600.1217
(0x78000000 - 0x7807e000) RPCRT4.dll        5.1.2600.1230
Register dump:
Context flags: 0001003f
Floating point registers:
cw: ffff027f  sw: ffff4020  tw: ffffffff  eo: 0ab02cb1  es: 0000001b
do: 00b33490  ds: ffff0023  ns: 00000000
Segment registers:
gs: 00000000  fs: 0000003b  es: 00000023  ds: 00000023
Integer registers:
eax: 00b11c08  ebx: 0ab1f458  ecx: 00000001  edx: 00a271c8  edi: 887601c2  esi: 0b050000
Control registers:
ebp: 00a27238  eip: 0aaad596  esp: 00a271ac
sc: 0000001b  ef: 00010246  ss: 00000023
Stack trace for thread 0x000009f8:
Instruction Address        Param 1    Param 2    Param 3    Param 4    Ins Offset DLL Name     Function Name
0x0aaad596 (0001:0000c596) 0x00000002 0x00afa3c8 0x00000010 0x00b33340 0x00000000 sisgl.dll    ???
0x0ab029cb (0001:000619cb) 0x00000002 0x62c5fec7 0x00000000 0x00000000 0x00000000 sisgl.dll    ???
0x0ab03138 (0001:00062138) 0x00000000 0x00000000 0x09c35ee8 0x00000000 0x00000000 sisgl.dll    ???
0x62c5fec7 (0001:0002eec7) 0x09c344a0 0x01559850 0x00000003 0x09c35ee8 0x00001837 RENDER.DLL   JDraw::DrawStrip
0x62d14528 (0001:000e3528) 0x01559850 0x00000000 0x09c35ee8 0x09c97ff8 0x00000238 RENDER.DLL   JRenderGL::Display
0x62d17172 (0001:000e6172) 0x09c97ff8 0x00000000 0x09c35ee8 0x00000000 0x00001062 RENDER.DLL   JRenderGL::Display
0x62d172c4 (0001:000e62c4) 0x09c97ff8 0x00000000 0x00000000 0x00a29968 0x00000024 RENDER.DLL   JRenderGL::Display
0x62d160a1 (0001:000e50a1) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000981 RENDER.DLL   JRenderGL::Display
0x0150e7fc (0000:00000000) 0x62d09720 0x62d07980 0x62d079e0 0x62d079f0 0x00000000 ???          ???
0x62d096ff (0001:000d86ff) 0x02c75756 0x00000000 0x0d3b088b 0x62e02f08 0x000002af RENDER.DLL   JRenderGL::QueryInterface
0x0824448b (0000:00000000) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 ???          ???
RE: SE Crash
the Access violation sounds like errors I used to get until I upgraded the video driver. We used to crash simply from moving a balloon in a draft. Very frustrating when you haven't saved in a while.
