NonLinear analysis with COSMOS
Dear people
I’m trying to simulate a coupling with interference (shaft has a diameter bigger than the flange) using COSMOS. I don’t know very well this software. Could someone give me some suggestions?
Manini
RE: NonLinear analysis with COSMOS
You will want to try "Shrink Fit" under Contact Pairs for this problem.
I am affraid COSMOS will not be the best for this task. See tests of it:  www.6dof.com
Irwin,
I could not follow on the website you gave where I would find tests.
Maybe you can explain to me why you think that COSMOS would not be well suited for this problem.
Thanks.
