Hi Temp cables
Hi Temp cables
Hi Temp cables
Do any members know of a cable manufacturer that produces cables, flexible tinned copper,1mm2,4 cores plus earth,rated at temp exceeding 155 degrees cel apart from copper clad MIMS type ??.
RE: Hi Temp cables
You could check out Hubner & Suhner (http://www.hubersuhner.com).
They have a cable called Radox 155 (See below)
RADOX® 125 or 155 multicore cable (screened or unscreened)
RADOX multicore cables are designed for various applications where high and very low operation temperatures and high resistance to ozone, weathering, oils and chemicals are needed. RADOX cables are highly flame retardant.
Characteristics
halogen free for RADOX 125
electron beam crosslinked
operation temperature -40 to +125°C for RADOX 125
operation temperature -55 to +155°C for RADOX 155
short circuit overload up to 280°C
high current carrying capacity
highly resistant to ozone, weathering, heat pressure, hydrolysis, oils and abrasion
flame retardant
soldering resistant
easy to strip and process
flexible
Tom
RE: Hi Temp cables
Suggestion: Visit
http://www.thomasregister.com
and type Cables: Electric under Product or Service, which will return 434 companies to inquire about the specified cable
RE: Hi Temp cables
Radix.
If you want high temp, high ampacity, and flex try them
RE: Hi Temp cables
Thanks All,
Have located some Radox 125.C on east coast that will do for now and have ordered some Radox 155.C from Switzerland for next time.
regards Mark
RE: Hi Temp cables
THANX jbartos,
Cheaper,I can call conductor colours, and go hotter ie 180.C
Sparky001
