Rules commonly used to install nuts & bolts correctly
I realize this may sound elementary. is there any documentation to support how we fasten a nut and bolt together? how many threads should be exposed at the end of the nut?
how many threads in a blind hole should have contact with the treads of a bolt?
I am talking about pressures that exceed 3000 psi.
I am looking for a rule of thumb that would apply only if the correct grade of bolt has been selected.
RE: Rules commonly used to install nuts & bolts correctly
Thread725-58264
Please give a little more information as to what your are trying to clamp or fasten. A pressure boundary on 3000# system usually requires more than generalized suggestions. Does this assembly come under a jurisdictional code or is it an application like hydraulic lines.
The thread that CWIC refers to mainly is for A325 bolts. Though some of suggestions apply to other bolts A325 bolts are not used at pressure boundaries.
A good reference book on bolts and bolting is:
An Introduction to the Design & Behavior of Bolted Joints by Bickford
This is a very good book though expensive (150 USD new). I have seen used ones.
You might want to check out www.marfas.com and check out the Technical section and the continuation of the technical page. I post as much free literature that I can find to assist engineers with fasteners and stainless steel. Before you pay for specific information, you might check out what is available free. For instance we have a link where you can download the book "Guide to Design Criteria for Bolted and Riveted Joints" /2nd Edition /by Kulak, Fisher, and Struik free on the internet.
I wonder how I missed this site when I was buying a lot of Marine Fasteners.
Paskenell kept up the good work.
QuakerT if you don't find the information you need on this site or need further help let evryone know.
