AutoPipe?
AutoPipe?
To anyone out there using AutoPipe for CAE Stress Analysis:
Is it possible to model pipe hangers realistically (in all directions) or does the program only model spring hangers in the vertical directions?
RE: AutoPipe?
When a restraint is inserted, V-stop or Guide, the user can input gap distances. When using a pipe clamp type hanger, I typically set the gap below and above the pipe to "0" for a V-stop. With roller type hanger, I use a gap below pipe of "0" and a gap above pipe of some absurdly high number, like 36 inches.
I use the same technique for guides.
Hope this helps!
