Creat tiff file form drw
Hi I would like to make .tiff file from .drw but with better quality like Pro/E made.Any help would be appreciated. Thanks
RE: Creat tiff file form drw
Hi Wermok,
To export Your Pro/E drawing (.drw) to TIFF Image (.tiff) kindly start as follows,
- Open your Pro/E Drawing
- Convert it into a ACROBAT READER File (.pdf) using any of pdf converter softwares (Try with PDF995 Evaluation version is available online http://www.pdf995.com; You can use their help
   to instal and working of PDF995 software.)
- Open the PDF file in Acrobat Writer and save it as .TIFF.
- Now the quality of your tiff file will be good and clear.
Hope this will help you,
K.A.Kamaleswaran
Member - Operations
Pricol Technologies
http://www.pricoltech.com
Pricol - Plant 1
Coimbatore - 641 020
India
Ph:      ++91-422-2692901
Fax:     ++91-422-2692028
E-mail: ptl@pricoltech.com
Wermok
We use this method to convert.drw to TIFF.
Use "print" and in "add printer type" you will find TIFF option. Choose print to file and give .tif extension to the file name. You can control the resolution up to 400 dpi in
config.pro with option "raster_plot_dpi" and compression with "tiff_compression". A typical A0 drw will be around
200 300K.
