Utility Impedance & Isc
2000 kVA transformer
4160 / 480 5%IZ
What would be a reasonable assumption or WAG ..
for available Short Circuit Amps ... and impedance on the utility side (4160)
Thanks ..
jOmega
4160 / 480 5%IZ
Thanks ..
jOmega
RE: Utility Impedance & Isc
As for the utility fault level any WAG would be absolutely that, except from the utility of course.
Ignoring the data from the utility and figuring the theoretical worst case:
Isc utility = [VA / (V *sqrt(3))] * [1/%Z]
Isc utility = [2000000/ (480 * 1.73)] * [1/0.05]
Isc utility = 48,112 A (symetrical)
This is the maximum let-thru from the utility transformer. You also need to account for your load. Assuming all motor loads to a maximum loading of 80% of capacity:
Isc laod = [(VA * %load) / (V * sqrt(3))] * 6
where 6 is the average inrush of a motor
Isc load = [(2000000 * 0.80) / (480 * 1.73)] * 6
Isc load = 11,547 A (symetrical)
Isc = 48,112 + 11,547 = 59659 A (symetrical)
This is the worst case disign requirements. Your load will have some non-contributing loads and the utility will be less than this. In-addition, your feeders will limit the current due to resistance and length. See Bussmans website for some literature for additional hand calculations on feeders.
But in absence of any data assuming anything less than 350 MVA could be a bold approach.
No utility system impedance Zsys. The system impedance Zsys will make the transformer secondary short circuit current level somewhat lower.
