Line changes when viewing in Paper space
I am working in R14 and in my years working with AutoCAD I have never seen this.
I have a center line (or for that matter anything BUT a solid line) in model space. When I switch over to paper space, the line changes from a center line to a solid one. This is happening on all the drawings created in a specific template. But weirder yet... When I print it out, the line shows up as a center line again. The property of the line does not change - it still is either bylayer (set to a center line) or center.
Background... I created a custom title block recently(which I have done many times and this has never happened). I'm not sure if I somehow goofed something up while creating the blocks, etc. BUT, when I moved this drawing to another title block, it still keeps on changing the line.
This problem isn't that big a deal - just bothersome.
Any help would be appreciated.
Thanks!!!
Thanks!!!
RE: Line changes when viewing in Paper space
Another weird thing... I created yet another title block yesterday. Now the new one has NO PROBLEMS.
I'm still curious if anyone out there has an answer!!
In the mean time, I'm creating a new title block and saying to heck with this.
Good Luck
try this
goto PS and set psltscale to 0 the goto model then back again to see if it clears up
1st goto model space and make sure your ltscale is correct
then set psltscale to <0>
when you go back to paper space it should appear correctly
if everyone helps everybody the world will be a better place
Thanks for everyone's help!!!
Model refers to model space
then i said goback meaning goback to paperspace
"try this
goto PS and set psltscale to 0 the goto model then back again to see if it clears up"
sorry if i wasnt clear ill do better next time
