Linked Mass Property
Is there a way to have the weight of model show up as grams in the title block instead of lbs? How do you write the link to do the conversion?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Linked Mass Property
This setting may or may not be the same as the setting under Document Properties. If it is manually changed, it does not seem to update with units changes under Document Properties.
Nice Rush quote in your Sig. I believe it is from "Red Barchetta"
