flat plate parallel to flow in wind tunnel
Trying to get some friction drag data, but not sure of the best way to suspend the plate in the flow. Any supporting rig will distort data....
- can the supporting rig be tested separately and then subtracted out? Flow field will be different with and without plate installed; and
- what is best way to support?
Thank you for your input.
RE: flat plate parallel to flow in wind tunnel
Air -> Test Section support
body_________\/
Hope this lines up right...
STF
