Gearbox lubrication in cold weather conditions
Hi all,
I am currently looking into the devolopment of a gearbox lubrication system to run in south tasmania for the firm i work for. Would anyone be able to recomend any credible websites where i could find relevant information on heaters, delivery systems and lubricants.
thanks.
RE: Gearbox lubrication in cold weather conditions
Why not search on
Gearbox lube?
The gearbox should have been designed by the original manufacturer with a specific grade of oil, specific flow rates and pressures and with specific inlet and outlet temperatures. This information should be the basis of your design for the lubricant supply system and should be available from the OEM.
