exploding polylines
exploding polylines
i need to explode a series of polylines into their constituent parts to re-position certain aspects of my drawing, and i know that when you do this, you lose the width, and the plines become lines. is there any way of reassigning a width to these lines to make them polylines again without having to go around and redraw them again?
also, just a quick question. is there a good way of filleting different polylines together to avoid the gap at the apex of the corner that i always get?
sorry if these are terribly basic questions. im sorta just having to learn cad on the job, so any help is very welcome.
RE: exploding polylines
- PEDIT
- M(ultiple)
<select entities>
- Y (for convert to polylines question)
- J(oin)
Accept the default value for fuzz distance
Hit enter to close the command
You should now have all of your lines and arcs from the original polyline back as a single polyline.
I don't follow your second question...
You can fillet two polylines with the "FILLET" command, specifying a new radius or using the previous value.
