Somebody can help me about laser cu
Somebody can help me about laser cutting and welding on enamelled steel? Does it works? which laser welding paramters do you use for cutting and weldig? Are there some other joining methods for enamelled steel?
RE: Somebody can help me about laser cu
LASER welding? if the usual fit-up requirements are met, maybe from the non-enamelled side?
If laser cut, there may be enough burn-back of the enamel to laser weld from the front side?
Maybe ask a friendly (or hungry) laser vendor to run some tests?
Jay
Jay Maechtlen
