Coupling friction vs fitted drive bolts
When a coupling (rigid) is designed to drive through it's face friction, should it be necessary to add the additional cost of "fited bolts" as a security matter?
RE: Coupling friction vs fitted drive bolts
The bolts are what carries the load.
Spend the money to get the bolts.
Edson Campos
edsoncampos@earthlink.net
