BROMINE METHANOL ETCHANT PREPARATION FOR 690 NICKEL ALLOY
I try to find how prepare the BROMINE-METHANOL ETCHANT SOLUTION (BrMeOH) to perform a SEM over a 690 nickel alloy. I already look for in the ASTM E 407 and AMS handbooks without any luck.
Thanks in advance for any tip or reference.
RE: BROMINE METHANOL ETCHANT PREPARATION FOR 690 NICKEL ALLOY
Safety first!
Bromine is a very hazardous material. Read the MSDS and the Technical Data Sheet prior to using this material.
Check out the following:
http://www.metallography.com/
There was at one time a link that was devoted exclusively to metallurgical etchants, but my link is dead.
Also NiDI  would be a great starting point.
One thing that I've found is that people tend not to recommend hazardous reagents as they once did.
I've had excellent luck with the mixed acids etch listed in ASTM 407 as I believe etch 89.  It is a mixture of nitric, hydrochloric, acetic and glycerin.  It does a great job etching grain boundaries, etc.  The solution starts out pale yellow and darkens over time (minutes); the darker it gets, the stronger it gets.
For nickel alloys, let it stand for 4-5 minutes or so and then swab.  Do not use after 30 minutes or so and do not store.
I agree with Unclesyd that hazardous etchants are not as popular now as they once were - I can't remember the last time someone used Murikami's...
