bracket stresses
bracket stresses
does anybody have a method of calculating stresses in pressure vessel shells due to weight loaded brackets such as structural brackets. I know about the Bednar and Megyesy methods tks but they dont address brackets which have a A/B ratio outside the limits of 1.5 or between 1/2 and 2 respectively...
RE: bracket stresses
Also, Blodgett,"Design of welded structures " has a section on bracket loads on a shell.
Design of Weldments by Omer Blodgett
This is a very handy and outstanding book and doesn't cost much ($12.50). 500 hardcover pages of formulas and diagrams
https://ssl.lincolnelectric.com/foundation/
Any pressure vessel design program will do a good job.
Don’t design too close to the minimum as someone is already planning to impose higher loads than your design.
Check some of you technical book suppliers in Australia. In the US it's carried by several. Lincoln should also have a represenetive there.
I know about the shipping to and from Australia, I've purchased several fishing reels from Alvey. Used the slowest method.
