Simple Electronics Guide
Is there a website that explains or shows how to build what I would consider simple electronic assemblies. I would like to put together some leds for stop lights and such and some simple circuits. Is there any reference out there for a nonelectrical type of guy? In a way, electronics for dummies. The most complex I would try is LCDs showing like temputure from a sensor or an alarm going off if a temp is acheived or a conditions is set. I know this is way below what you guys in here are used to, sorry to bore you with simple things.
RE: Simple Electronics Guide
Another is www.epanorama.net
So reading about that stuff is hard for me more then other subjects, I cant seem to digust it as easy compared to others. Some in terms of explaining how a system worked, like LED's. Something that said how they worked, what they needed to work, most common configurations, and so on. I am probaly way off, asking too much. I think I might check the college and see what classes I might take.
Even relatively simple circuits, such as those in Radio Shack 10-in-one or 100-in-one kits, can be rather mind-boggling to reverse-engineer without having been trained to recognize some relatively common circuit topologies.
By the way, those 10-in-one and 100-in-one kits are a great source of basic circuit schematics and a cheap way to experiment on them. Unfortunately, the kits do not provide much in the way of explanation of how the circuits actually work or how to design similar circuits.
Otherwise, there is plenty of information on the web.
http://www.drbob.net/otherlinks/index.html
