Anyway to change project # & custom
Anyway to change project # & customer name in title block without go thru SW explore & change individual one.
it's very helpful if someone solve this out
thanks
RE: Anyway to change project # & custom
2433 ...
If you use CUSTOM PROPERTIES within SolidWorks (for either Part, Assembly, or Drawing files) all you need to do is open a Windows Explorer goto the directory where the file is located and then simply RIGHT mouse click on it.  Select PROPERTIES and then click on the CUSTOM tab and you can edit anything you create for a Custom Property for that file without having to go through SolidWorks Explorer or firing up SolidWorks.
Hope that helps ...
Cheers
Brian Mazejka
Project Engineer
L-com, Inc.
Thanks for quick replied, That's mean I have to go to individual file and change it (200-300 dwg/project). The reason I ask because some time I got new project is very much same as an old one, what I need to do is change customer's name and new project #,
thanks advange
There is a SW utility program called "Propagator" that may help.  Maybe someone out there can point the way to it.
All this machinery making modern music can still be open-hearted.
Go to the SW applications library and search API for "custom". You will find several utilites related to changing properties and doing mass updates.
Crashj 'never attribute to malice what can be explained by blind stupidity' Johnson
