Hi all, I need to know how to remov
Hi all, I need to know how to remove unwanted duplicate objects. I've made a drawing and somehow I've copied the entire drawing three times over itself. Now I have to click every object and select remove twice in order to delete the duplicates. There must be a command inside AutoCAD to delete all unwanted duplicates or to list them. My AutoCAD version is 2002 LT. Thanks in advance!
RE: Hi all, I need to know how to remov
I don't know, how You can remove duplicate objects in ACLT.
...Maybe You can buy the Lt-Extender ( http://www.lt-extender.de/englisch/frameset.htm ), and then You can use *.lsp-files ( Thread555-48939 )
...or You can mail to someone, who has the full-version and the "delete-duplicate-objects-tool"!
Lothar
OVERKILL removes objects whose geometry is redundant. For example:
Duplicate copies of objects are deleted
An arc drawn directly over a portion of a circle so that the arc cannot be seen is deleted.
Two lines drawn at the same angle so that they partially overlap are combined to form a single line.
Duplicate line and/or arc segments within polylines are removed.
Flores
