3500psi steam
3500psi steam
I am searching for a system that is injecting steam at 3500psi and 800F. The object is to have the steam the same volume as water. Anyone know of anyone using these parameters?
Roy
rroybentley@cs.com
Roy
rroybentley@cs.com
RE: 3500psi steam
RE: 3500psi steam
3500#/800 oF steam has a spec vol. of ~ 0.135 ft^3/lbm
RE: 3500psi steam
http://webbook.nist.gov/chemistry/fluid/
RE: 3500psi steam
RE: 3500psi steam
http://www.mpshq.com/products_boilers.htm
http://www.bbpwr.com/flderec.htm
RE: 3500psi steam
Generally the these small units are heated using an electical heater. I understand it is difficult to get a centrifugal pump in this size range for that high a developed head, so the use of positive displacement pumps with snubber bladders ( to reduce pressure pulsations) is resorted to.
RE: 3500psi steam
RE: 3500psi steam
