Absorption Type Refrigeration
What is the range of application of a conventional vapor compression refrigeration which cannot be served by an absorption type? My application is on room comfort cooling.
RE: Absorption Type Refrigeration
For comfort cooling vapour absorbtion system can be used if you are getting some waste heat.
Lithium Bromide-Water system can be used upto a minium temperature of -5 deg C and Ammonia-water system can be used upto -30 deg C below this temperature heat ratio is very low and you need a very high temperature heat source.
KMPillai
There is typo error in my above reply. Lithium Bromide-Water system can be used upto a minimum temperaure +5 deg C.Since in this this system water is acting as a refigerant and we cann't go for the negative temperatures.
KMPillai.
First I would like to know what is the source of the heat energy available for the absorption refrigeration and what is the capacity of refrigeration system required.
regards,
KMPillai
Olmedo
www.tespl.com
regards,
KMPillai
