EQUALIZED REAR TIRE LOADINGS FOR DRAG RACING
I have been searching, since my days with the Ramchargers in the early sixties, for means by which rear tire loading could be equalized in a RWD, suspended car without IRS. I've summarized much of my work in an article at:
http://racingarticles.com
I did not include, in that article, a discussion of pinion shaft angle. It would appear that initial efforts, by drag racers, to adjust the pinion shaft angle, were merely to compensate for suspension deflection during launch. But, I strongly suspect that some have realized a beneficial effect when the pinion shaft is angled down more than necessary. With a "beam" axle, it is very apparent that a horizontal pinion shaft will result in an unloading of the right rear tire due to driveshaft torque. If the pinion shaft is visualized as pointing down (vertical), it becomes apparent that the right tire unloading is gone, but, instead, driveshaft torque would tend to push the right tire forward, wedging it underneath the instant center and resulting in increased vertical loading. So, with a load reversal between horizontal and vertical configurations, it is also quite apparent that there exists a pinion shaft angle, somewhere between horizontal and vertical, at which rear tire loading would be equal. The following defines that condition:
sin(alpha)tan(beta) = cos(alpha) - V
where alpha is the angle, positive down from the horizontal, of the pinion shaft, beta is the angle of a line through the tire patch and the instant center, measured positive up from the horizontal, and "V" is the ratio of rear roll stiffness to total roll stiffness.
Insertion of reasonable values quickly indicates that the alpha angle would normally be so large as to be impractical. The interesting point is that the drag racers have realized the value of even a partial achievement of equalized rear tire loading.
RE: EQUALIZED REAR TIRE LOADINGS FOR DRAG RACING
I don't understand your point about roll stiffness in the article-if the car has completely rigid suspension at the rear it will still see an increase of load on the rear wheel, won't it? I'm 99% sure of this, just by conservation of angular momentum.
Cheers
Greg Locock
Reaction to the driveshaft torque is carried into the chassis through the engine and transmission mounts. The chassis then responds in the same manner as it would if the car was cornering (except that, since this is a pure couple, roll center heights are not considered). So, if all the roll stiffness is at the rear, driveshaft torque is completely cancelled and rear tire loading is equalized.
Thank you for your comment.
Sit in a car with the engine running in neutral. Blip the throttle. Are you telling me that the resulting body roll does not increase the loading on the tyres on one side?
Cheers
Greg Locock
With regard to your original point concerning pinion shaft angle, you appear to be ignoring the effect the axis of torque tranmitted to the pinion shaft via the U.J. from the propshaft. I assume your engine/ gearbox is not situated below ground level on the pinion shaft axis (although that would be a nice solution for a drag racer!). If (for example) the propshaft runs horizontal and is coupled to an angled pinion shaft via a U.J., then the nett torque transmitted to the axle still acts about the propshaft axis.
Pete.
We are right hand drive in OZ, so we move the driver back and keep him as close to the right hand side and as far back as possible.
As we are about 1100 HP and probably about 700 foot lbs of torque, we need a very robust axle assembly. A broken CV joint on the low to top gear change would not be a good thing I'm sure, and appart from pinion reaction on the crown gear, the torque reaction of the motor must find it's way to the outside world somehow, or at least that's how I understand Isaac Newtons explanation.
pat
PT, the torques acting at each end of the driveshaft are equal in magnitude and opposite in sense. The one torque acts on the rear axle housing and the other on the chassis. The torque on the chassis is distributed, front-to-rear, in proportion to roll stiffness. If all the roll stiffness is at the rear (a situation which can only be approached in practice), all of the chassis torque is carried back into the rear axle by the suspension, thus completely cancelling the tendency to lift the right rear.
The whole idea of a U-joint is to redirect torque. Free body diagrams of the yokes and cross indicate that the torque entering the rear axle assembly is determined by the pinion angle. If it were as you suggest, what would happen if you had a dozen shafts coupled with U-joints, with the initial shaft at a right angle to the final?
Taking your second point first, if you couple shafts and UJ's as you describe, they will try to 'wind up' when loaded. To transfer torque from one plane to another, you would need to support the intermediate shafts of the arrangement in bearings, which in turn need to be supported to 'ground' to react the loads created within the system. In the case of your beam axle, it would require an outrigger bearing on the pinion shaft, anchored to the chassis, to 're-direct' torque to the pinion shaft axis. In the free body diagram of the propshaft/UJ/pinion shaft, note that the cross changes it's angle relative to each yoke as it rotates, generating loads axial to the pinion shaft, which resolve to a secondary couple force at 90° to its axis.
With regard to your second point, you are entirely correct in that torque is equal within a rigid chassis in the steady state. My point (and I beleive Greg's) was relating to the accelerating mass of the rotating parts of the engine and transmission. This may be regarded as transient, but it is just as transient as the acceleration of the car as you power out of a corner, and is not to be ignored. Anyone who has ever ridden a BMW or MotoGuzzi motorcycle will be well aware of the effect.
One possible advantage of pinion shaft angle would be moving the axis of the propshaft away from the rear roll centre, so that more of the load is taken through the links, and less through the springs.
Pete.
Im very interested in your findings on this subject. As I describe on another thread (Mallock TAM and Mumford links) I am interested in improving my live axled sprint cars handling. This includes standing start take off with maximum traction and without impairing overall handling. Someone has once told me that inclining the diff nose one way or another would help, but wasn't sure which way. From your reasoning, it would seem that its with the nose down, but by how much is the problem?
I am following the thread with great interest.
John
I would, instead, recommend the asymmetric trailing link suspension, as used by Jaguar.
Pete, as the title of this thread indicates, I'm interested in addressing the tire load problems facing the dragracer. While all the loads can certainly be considered transient (what else can be said about an event that lasts only a handful of seconds), transients involving drive train inertias are of such duration that they can be safely ignored. (For performance calculations, drivetrain inertias are usually converted to equivalent masses and added to the mass of the total car.) For those cases which you cite, where the car (or bike) is performing at the periphery of the friction circle, even small inertia loads can cause problems. But, with a drag car, that extra load is simply included in the thrust required of the tires.
I said that the purpose of a U-joint is to redirect torque. That is a simplification, of course. Instantaneously, the pinion torque vector is always conjoined with the pinion shaft axis, but it is not constant in magnitude. With a cross-type U-joint, the torque received by the pinion shaft is equal to the driveshaft torque when the pinion arms are perpendiculat to the plane of U-joint angularity and equal to the driveshaft torque divided by the cosine of the angularity when the pinion arms are in the plane of angularity. Since power out cannot exceed power in, the pinion shaft speed must change accordingly. The preceding is assuming constant driveshaft torque and speed. As is evident, large U-joint angles are to be avoided, which gets us back to my comments to John.
Sorry to dwell on this point, but I think we must be at crossed purposes. The effect I have been trying to explain is easily observed in a T-handle spark plug spanner equipped with a universal joint. If you try to use this tool on a normal nut, with about 45° angle on the UJ, it will tip off the nut when torque is applied. The only reason it works OK with the spark plug is because the plug itself maintains the alignment of the spanner portion.
The function of a UJ is to allow the redirection of torque. When the torque changes axis, the difference between the input and output vectors must be reacted to the outside world. In the case of a live axle, this happens through the pinion shaft bearings.
I have discussed this subject with a couple of my colleagues. We are of the opinion that there is scope for changing the dynamics of the live axle suspension by alteration of the pinion shaft angle, but the observed effect is the result of offset between the propshaft axis and the rear roll centre.
Incidentally, there is a secondary torque effect from the gearbox shaft angle, but the length of the propshaft makes its effect small at the axle.
Pete.
In short, except for a unique situation, which comes to mind, where the driveline was angled steeply up from the axle and cancelation was to have been achieved through an asymmetric trailing link suspension, I consider this a discussion without any value.
In short, I agree. Thanks for indulging me.
Pete.
