Custom Properties
Custom Properties
Is there a way to use custom properties to fill out the title block in the draft file? (I tried searching for a thread about this but couldn't find one) Thanks for any help.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Custom Properties
If you are inserting custom properties of your drawing into your title block, use $PRP:"Custom Prop".
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Check out http://www.nhcad.com/ if you want to make this task easy for everyone to link custom properties. In left column look at SolidWorks API Tutorials, Macros/Examples, "Example 7 - CONFIG PROPS.SWB will write several custom properties to active configuration". Joe Jones did a very nice job of explaining this task.
Bradley
