sheet formats
sheet formats
How can I replace an existing format in a .slddwg with a new sheet format? I only have drwdot drawing templates from the Company whose format I want to use!
David A. Johnson
Thunder Systems Inc.
Corona, CA
RE: sheet formats
RE: sheet formats
David A. Johnson
Corona, CA
RE: sheet formats
Open the template file (the *.drwdot). To do this, select "Templates" from the file type selection box in the "Open" menu. Once the template is open, you can export the format using "File --> Save Sheet Format".
