adding separator to toolbars
SW2003 SP3.1
I can't seem to find a way to add a separator to the toolbars when customizing. Is this possible??
DG
DG
RE: adding separator to toolbars
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
You can't add these, but you can modify an existing toolbar that has one and remove and add icons as required around the seperator.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thnaks,
DG
