Loctite Potting Material
I am having a great deal of trouble with the Loctite Encap potting material. I have been touble shooting for months and am getting little support from our area rep. I am wondering if anyone else is having trouble with inconsistent curing of the Encap material? I purchase the material in quart size cans and mix it by hand. I thouroghly mix the product and pot ten sensor housings. I will have six good, four bad, and the material in the cup is good. When I say good I mean the material has cured properly and is not slimy. Thanks
RE: Loctite Potting Material
The other possibility is that something in the unit that is being potted is not compatiable with the epoxy. The literature for the epoxy (Endcap) should give a list of these materials.
You are probably not vacuuming this unit. Putting a good vacuum on epoxy before it hardens will pull the hardner out of the epoxy.
