Creating a flat of a vase
I am trying to take the surface profile of a vase and make a flat, but it is giving me heck.
RE: Creating a flat of a vase
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
A Gaussian surface is any surface which can be unfolded to a flat. Basically, this means cones and cylinders and flats joined in any combination along tangents.
There are programs that stamping toolmakers use to develop flats for non-Gaussian forms. They are not part of any CAD package. Toolmakers used to develop such flats experimentally, using sheetmetal marked with a pattern so that the deformation can be charted and back-solved.
It's been 2 years since I was on Pro/E. I do like to lurk in this forum to see what's up. Please excuse me if I'm a little behind the times.
Pro/E did not accurately form the hole pattern into the new complex shape. Rather it made the complex shape, and then projected the hole pattern onto it.
I don't know if this is relavant to your task, but it was interesting. Makes me less confident in flattening complex-shapes and getting an accurate hole pattern in the flat pattern.
check this out:
http://www.ptc.com/appserver/it/icm/cda/template_lib/multistep_textimg/main_v.jsp?im_dbkey=11603&icg_dbkey=382
The flat pattern shown no deformations or the like, though leading me to believe it is not very realistic.
