v4 export into v5?
v4 export into v5?
v4 export into v5?
Hi all,
   Was wondering if it is possible to bring in v4 export files into v5 or is it possible to change v4 export files into .model files?
                                         Thanks tons
RE: v4 export into v5?
You can import V4 export files in V5 by using the "ExtractModelFromSequential" utility.
Select "Utility..." from the "Tools" menu, then double-click on "ExtractModelFromSequential".
Click "Browse File" to find the export file, and then set the target directory to write the models to.
I think, however, to use this utility you may need to set a path to the V4 project tables from the "Tools->Options" panel.
Hope this helps...
Marc
