FORCES DUE TO THERMAL EXPANSION IN CONCRETE
If an infinitely long (theoretically) PCC SLAB-ON-GRADE is rigidly constrained (non-yielding) on the two edges, what would be the buildup in edge forces, in psi, thru a range of delta T (F°)? The slab has no expansion joints either longitudinally nor along the edges. The slab is 5" thick and minimum 3,000 psi compressive strength specified. In this case the slab is twenty five (25) feet wide. In another location it is 28 feet wide. T (F°) varies seasonally between 34°F and 110°F.
RE: FORCES DUE TO THERMAL EXPANSION IN CONCRETE
