Units on Graphs
Units on Graphs
Units on Graphs
I am trying ot create flow graphs based on a calculated Cv value, with pressure loss shown in PSI.
Function works and gives me default units of lb*ft^-1*sec^-2, at which I insert psi and all is well
However, when I try to graph it, I get the default units, if I type psi in the y column I get changed, but wrong results. Does anybody have experience in creating graphs where you change the output to a "non-standard" unit??
RE: Units on Graphs
Divide the data set by psi and plot.
CRG
RE: Units on Graphs
Alternately, you can divide your abscissa on your graph by the units you want in the plot.  This avoids losing the units for other equations.
TTFN
RE: Units on Graphs
Thanks for the help...counterintuitive it seems.. but efective!
