RJ45 panel mount jack
I'm looking for an RJ45 jack with leads that I can mount into a cutout in a metal chassis. Will a jack that fits into a "Keystone" cutout work? What are the dimensions of a standard "Keystone" cutout.
Thanks for the help.
RE: RJ45 panel mount jack
Care to elaborate?
Post the information you've seen. Then, maybe I can get an idea of what you're talking about.
http://www.mycableshop.com/sku/KEYSTONE110.htm?x=22&y=9
However I'm looking for this type of connector that has leads coming out of it instead of the "punch-down" method.
Thanks.
Reuben
Have you seen oe used ethercon connectors? Neutrik makes one that will work, is chassis mountable and even color coded if you wish.
Do a search for ethercon connectors. Or, see an example here. http://www.maaselectro.nl/nedparts/Q287.HTM
