Unhandled Errorrs
Unhandled Errorrs
I have an assembly I have been working on and the assembly file opens up with no problems but when I go to open the individual models of the assembly I get an unhandeled error message and Soliworks stops. I have heard of the unhandeled errors problem before but why would it let me open the assembly and not the individual models. I have even been able to modify the individual models in the assembly with no problems. How can this happen?
RE: Unhandled Errorrs
In my experience flaky hardware (such as memory) can be a significant source of Unhandled errors. The problem gets even worse with large assemblies.
Try your files on another computer. See what happens.
I once mixed a couple different speeds of RAM in my machine. BAM unhandled errors at least 3-4 times a day. I removed the odd-ball memory module and unhandled errors went to almost nothing.
C:\Document and settings\[Login name}\Local settings\Temp
If you can't find your Local settings it is because it is hidden and you have to unhide it. Go to Tools\Folder Options\View Tab\"Show hidden files and folders" Check this option on.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
I'm having a good vacation... A bad day of Fishing
Scott Baugh, CSWP
FAQ731-376
