welding heat treated cast aluminum
After welding (GTAW) A356 T6 aluminum casting is it necessary to heat treat the casting again to obtain T6 properties. This is not foundry welding but a repair of a cracked casting that is already in the T6 condition. Will the casting ever reach T6 during room temperture aging? How long will it take?
RE: welding heat treated cast aluminum
