torque patterns
torque patterns
torque patterns
I have been unable to find a rule of thumb(standard) for torquing stands/adapters using a star pattern or any other pattern.  Is there a percentage or amount of the total torque that should be applied on each pass?  Does such a standard exist?
RE: torque patterns
A rule of thumb that is used for flanged gasketed joints (piping, heat exchangers, etc.) is to take the torque up in 3 roughly equal increments.  Using star pattern, torque all to ~30%, then to ~60%, then to 100% of desired torque.
RE: torque patterns
Look in ANSI B16.5.  It gives you torquing values and patterns for flanges.
