pro program brains!
pro program brains!
pro program brains!
Ive created an assembly  consisting of
1 interchange group 'heads'
and 'handles' controlled by if/else statements
The handles are obviously designed to fit the heads! On some occassions the 'heads' change diameter, which means the 'handles' have to also adjust to that dimension.
Although i have put relations on the handles to follow the 'heads'
I am having great problems!
The handles wont regenerate properly.  Ive started to put the relations on the actual 'handle' part file, but this wont regen either.
The heads all have the same relation title, 'rad_handle_liner' but because in assembly they change to 'rad_handle_liner:4' etc
I just cant seem to control the handles!
Any ideas?
