Subtract function in 3D
I am receiving a new error when trying to subtract a solid from another in 3D. The error is : Inconsistent Containment of Intersection Curve. I started with a copy of the object and sliced a segment off. Now I'm trying to subtract that segment from the original piece.
RE: Subtract function in 3D
Don't know how to fix it, Ive had to either start the component again from scratch, or think of a different way to get the same effect. eg can't you slice the bit off the original? or use a separate extruded shape? You could try to offset the subtracted solid to make it noticably bigger than the other, so there are fewer coincident edges...
If this is part of a large or complex drawing, draw the part from scratch on a new dwg and import it. Sorry I can't be of any more help.
