Fasteners
Fasteners
Does anyone have a reference that specifies the effective surface area of different size bolts? Thanks in advance.
RE: Fasteners
RE: Fasteners
RE: Fasteners
Available for download at:
http://www.spstech.com/unbrako/htm/unbrakodl.html
RE: Fasteners
Cory
RE: Fasteners
RE: Fasteners
RE: Fasteners
The Aluminum Association "Aluminum Design Manual" second edition uses the root area for calculating tension and the root or nominal area for calculating shear depending if threads are in the shear plane or not. The allowable stresses again vary with material.
I'd bet that the ASTM, AMSI and US Military have specs for fasteners of many kinds.
RE: Fasteners
RE: Fasteners
SAE AS5054, "Areas for Calculating Stress or Load Values for Externally and Internally Threaded UNJ Fasteners"
ASME B1.1-1989, "Unified Inch Screw Threads (UN and UNR Thread Form)"
FED-STD-H28 - This has many parts which cover multiple kinds of fasteners.
Hope that helps.
Randal Heller
