Special configuration on a dwg
I have an assembly with two configurations. I have the default config on it's own dwg. The two configs are each used on sepaerate assemblies. How can I use the other config on the other dwg? It is only using the default config. thanks
RE: Special configuration on a dwg
When you insert a view, right-click the view's icon in the manager tree, and select "Properties".  Under "Configuration information", you will be able to select which configuration is shown in that view and its subsequently created children.
All this machinery making modern music can still be open-hearted.
ugh! So easy. I thought I tried everything.
Thanks bunch Tick
