EModelHoops.dll can not be found
Hi all,
I'm currently using acad 2000 with workflow and when I select to go into acad and error "The dynamic link library EModelHoops.dll could not be found in the specified path shows up. The rest of the error is all the paths in which it has searched. Once you select OK it seems to run fine. How do I fix this error message?
Mokie
RE: EModelHoops.dll can not be found
you can do a search for the file "EModelHoops.dll" using explorer.
search all hard drives and any network drives.
 1.  if found on your machine and the path looks correct then add that path to your support paths searched by Acad.
2.  if found on another machine, copy latest file and put in same path on your machine then step 1.
hope this helps
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
OZZY84,
Thanks for the fast response.
I haven't been able to locate the .dll file but maybe this might help you with my issue. This is the information from the text window in autocad.
"Loading the AM-WorkFlow Document Server Interface. For Help type AMWHELP
K:\acad2000\EDWAutoCAD2000.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'K:\acad2000\EDWAutoCAD2000.arx'"
just a thought try to find the .dll file that is missing on the workflow install disk then try to place it in the correct path.
if this doesn't work then i would go to their web site
http://www.cyco.com/amworkflow/specialnews.html
seems they want you to up-grade.
hope this helps
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
