Can 2D in DXF unfolded as sheet blank?
We have problem finding a software that can suck in 2D drawings files and unfolded into a flat developed blank with accurate hole locations and proper notching.
RE: Can 2D in DXF unfolded as sheet blank?
Has worked good for me so far. SW works well with sheetmetal.
regards
So ctopher is correct - you need to make some sheet metal from the imported 2D DXF/sketch first. THEN you can unfold it.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
