Copy a sheet to a new workbook without the links
How do I copy a sheet to a new workbook in Excel without establishing the links to the original sheet? Right now, my code is Sheets("Sheet1").Copy. But that establishes links back to my source workbook. I just want the values. I know I could use select all of the cells I want to copy and then use the paste special command, but I'm actually copying more than one sheet. Any ideas?
Thanks in advance for the help.
RE: Copy a sheet to a new workbook without the links
ActiveSheet.UsedRange.Value = ActiveSheet.UsedRange.Value
Mutt.
No code required
Highlight Sheet1
Edit
Copy
Go to Sheet 2
Edit
paste special
Select value
Edit
paste special
Select format
