Pressure grouting
Pressure grouting
I have a restricted area under a machine where fixators and shim plates are installed in a grout pocket, I'am having trouble getting the grout in this area without leaving a void! Is there a tool or etc. that I can inject the grout into this area without leaving a void?? I have about 1" of clearance to work with.
RE: Pressure grouting
The air lock is probably a result of a warped or non-flat mounting or base plate.
Good luck.
