FRP rebar and Pultruded Rods
I am interested if existing Literature and/or Research reports exist of studies of fiber types and resin types regarding their resistance tothe high alkalinity environment of concrete and/or salt water exposure? Any help is appreciated.
RE: FRP rebar and Pultruded Rods
bye
As syntetic fibers the best is polypropilen fibers, because nylon and PE fiber consumed water from the mixture and difficult to make stable the concrete.
Sorry for the delay. If your offer still stands, send to:
Engineering Services
721 Richard Street
Miamisburg, Ohio 45342
Thanks, I appreciate the help
but what is your name?
I am David Niday.
You may be interested in the fact that ACI Committee 440 issued a draft on Provisional Design Recommendations for Concrete Reinforced with FRP Bars. A Draft 3 was issued in January 1999. If you contact ACI (American Concrete Institute) you might be able to get a copy.
Mike
1122 summit St.
Eau Claire, WI. 54703
Thanks alot, I would really appreciate it..
does any one know if there is any work performed on GFRP reinforced concrete shrinkage or creep?
Your help is highly appreciated
