Bearing Strength
Bearing Strength
Bearing Strength
Is the bearing strength for concrete on concrete different then for steel on conccrete?
This may just be for masonry.
Thank You!
RE: Bearing Strength
The specified maximum strengths are different, using different formulations. Other thing is that the behaviour is different enough to make such distinctions were not because of the different philosophies in the codes.
