Glass Bursting pressure
I need to know the bursting pressure of both laminated glass (100mmOD,3mm thk) and Toughened glass (100mmOD,3mm thk).
Do I need to do the test myself and find out or would this information be available with glass manufacturers / reference books etc.
Thanks in advance.
Pras
Thanks in advance.
Pras
RE: Glass Bursting pressure
http://www.technicalglass.com/tgphiqu.pdf
GE has some online calculators for thickness of quartz glass pressure vessels and viewing windows. Example #1, for 100 mm diameter tube and 3 mm thickness, allowable pressure is 30 psi. Example #2, for 100 mm (unsupported portion of diameter), a 3 mm thickness can only withstand 3 psi. These are for a max. design stress level of 1000 psi.
Imagine that you can make a proportional adjustment according to the physical properties of whatever glass you are using.
http://www.gequartz.com/en/tools.htm
