ATF in manual gearbox?
One of the two helicopters I fly for a living (both are Sikorsky S-76s) uses Mobil 254 (primarily a turbine engine oil) in the main, intermediate and tail rotor gearboxes.
The other heli uses ATF in the gearboxes, (Mobil 254 again in the engines). Both oils have similar viscosities judging by how they pour when we top up.
A while back a colleague's car needed a new driveshaft CV joint and he was helped out by a friendly helicopter engineer. After completing the work, they put Mobil 254 in the gearbox as it was "freely available". It is still going strong as far as I know.
I hav almost finished rebuilding the tranmission of my little trials car, which has just an 850cc engine. Power losses through transmission drag are a significant percentage of the total engine power available (only about 50 bhp at the flywheel estimated), especially as I just have changed to a small van axle for extra strength.
All this has got me thinking about suitability of oil types, viscosities, etc.
It makes sense to use as light an oil as possible in the manual gearbox and (hypoid) rear axle. However, the manufacturers' recommendations are 80w in the gearbox and 90w in the rear axle. I have previously been using a semi-synthetic 75/90w.
Could I use ATF without compromising longevity or reliability? (Mobil 254 is actually extremely expensive so I won't be using that).
For years I thought that ATF was only meant to be used in automatic boxes, but in view of the helicopter using it, is this not so critical?
BTW, I am aware of the requirement for a sulphur additive or similar to reduce wear due to the higher contact loads and "sliding" motion in a hypoid axle rather than in a straight cut gear set.
RE: ATF in manual gearbox?
ATF, in general , works well in automotive standard gearboxes.  I was concerned,as you are, when I first switched in 1967!!!   28 years in several street and racing  Lotus Cortinas and Elan gearboxes, Leeson, Jack Knight, Ford, all worked perfectly and never had a problem. The gearboxes ran cooler and shifted smoother but they WERE a bit noisier in normal operation.  Ford used ATF as standard OEM in my 1983 Thunderbird T-Coupe and I had over 200,000 miles when I traded it in 1995.  There are extensive threads dealing with all this but, I don't have the patience to look them up.  I am sure the folks out there that will speak to the added leakage problem but, in all honesty, I just have not had that problem.  Several mfgrs. aside Ford are currently using ATF as standard in manual transmissions.  I am even contemplating using ATF synthetic in the gearbox of my 1948 Norton at next service to see if it will smooth up the shift.
Rod
So ATF is safe to use in any manual transmission? The trans in my truck could use some new synchros and it's almost impossible to shift when cold, especially into 2nd. In the winter time i usually shift from 1st to 3rd until i've driven 3 or 4 miles and the trans has warmed up. I was going to flush it out and put synthetic gear oil in but i'm wondering if atf will work better?? I know most FWD vehicles are using ATF in the differentials. I believe the trans is an AX-15, used by both Toyota and Dodge.
-Jon
PEW,
From a user perspective: I have Dexron III in my Borg Warner T5 manual gearbox fitted to a 3.8 litre V6 with 478,000 Klms (about 250,000 miles) and have had no problems to date. It is changed every 50,000 klms.
The change to ATF came on the advice from Borg Warner Australia who confimed the suitability.
Practically there is no difference for the driver ; the cold shifting is smooth and notch free and the 'box is as quiet as it was previously.
Hope this is of some help.
Cheers, Pete.
Thanks for the replies.
It seems that as long as ATF can be kept in the box rather than on the floor, it should be OK.
Another thing that occurred to me is the fact that my gearbox has brass / bronze material synchro cones. I have read that EP (sulphur based) additives are actually bad for these metals but the manufacturer recommends an EP oil. Doesn't make sense to me, in the past I have had to rebuild a couple of gearboxes on cars I owned purely because the synchros were bad.
Paul W
The local refinery / lube supplier put on a seminar recently.  He mentioned that the only reason their company still produced EP greases (may apply to other lubes) is due to old specifications and people designing using old references and specing EP.  The particles have been shown to increase wear when overloaded.  In particular older "moly" lubes which use chrome-alloy particles are the worst.
Ken
EP additives can indeed wear away synchromesh materials at a faster rate as wished for. another by-product of EP-additives may actually be friction reduction, which may lead to longer shifting times and possibly overheating of synchros. standard gearbox oils do use a certain amount of EP additives to prevent tooth wear - the art in making a gear oil is to strike the right balance between wear protection of gear surfaces while at the same time not compromising the synchromeshes. usually this is achieved by using less EP additive (API GL-4 level) whereas backaxles usually contain twice as much EP-additives. The latter products should be avoided in gearboxes unless explicitly required by the manufacturer.
In my experience, it is better to use ATF for synchroniser performance in manual transmission in general. Especially it is good for shifting in cold weather. But it won't be good for speed gear durability since lower viscosity will make the oil film thickness thinner in the gear mesh. Also, the EP (sulphur additives) is harmful to the durability of bronze synchroniser rings as many folks have pointed, which ATF may have. But many types of oils for manual transmission have sulphur based additives as well.
But we have to know that helical gears in automatic transmissions last enough for its life in ATF.
In conclusion, ATF should not be a siginificant problem in manual transmission.
So is it safe to say that instead of the 10w-30/10w-40 motor oil recommended for use in my Honda Civic 1.5L manual gear box, that A/T fluid (Dexron, Mercon, etc) which one or are they all OK? (Synthetic or Non-Syn or both). Also, if the above oils are recommended is it also safe to say that 5w-30, 5w-20, 0w-30 and 0w-20 motor oils are OK alternatives. (Synthetic, Non, or both)
Steve
Two critical issues:  Viscosity and Additives.  Many manual transmissions are designed for ATF.  These normally have wider conical brass sincronizers and cannot displace a 80w90 gear oil (Ford/Mazda is in this group).  But if you reduce the viscosity of the oil below the designed point, you lose hydrodinamic lubricacion and cause higher wear.  Each transmission is designed for specific weights or ranges.  I know a company that standardized their transmission fluid at 80w90 in their fleet of trucks between Volvo and Scania.  The Volvo needs 80w90 while the Scania needs 85w140.  At 240,000 kilometros the Scanias are showing severe wear and one failed.
Additives:  The standard Sulfur/Phosforous package used for EP can be detrimental to bronze sincronizers as mentioned, but this can be avoided with Inorganic Borate EP additives such as those used in Chevron's Delo Gear that do not form chemical bonds with the soft metals and then peel off.
PULLLEASEEEE...
use the FACTORY recommended lubricant in whatever it is you are lubricating.
Example.....dont ever ever use automatic trans fluid in a GM/Saginaw power steering pump or box....use the correct GM power steering fluid.
Especially in transfer cases made in the 80's and later in 4WD trucks it is IMPERITIVE that you use the factory fill.
Now this is a litle less important in pre 70's vehicles that just specify "engine oil" or hypoid gear oil".
In some standard transmisions there is specified certain lubricants other than hypoid gear oil or motor oil.....use what the manufacturer specifys...this is extremely critical for LONG life....ZF, Borg Warner 5 and 6 speeds especially.
Auto trans need their specified fluid....DexronIII, Honda, Toyota all have a different and specific addative package.....due to the higher usage of ATF in Dexron and Mercon, other brands than factory fill are made to these exact specifications and would be acceptable.
Well, idano, aside many OEM's recommending ATF and the fact that I have had zero problems using it in the above mentioned gearboxes---when in search of improved performance, risk nothing, gain nothing!  If you just follow the herd, take a peek at the best view you can expect to see !
Welcome to the forums.
Rod
idano or others
Can you provide any insight into the correct/acceptable lubricant for the ZF6 transmission as used in 1996 Corvette?
GM speicifies a special 5W30 lubricant, which no one else has available as equivelent. ZF now says to use Castrol TWS 10W60.
What gives????
no_stray_voltage@yahoo.com
   For what it's worth some outboards, in the 60's and 70's, had electric shift gearcases (essentially a differential) in which the standard 80w90 was too heavy for the shift solenoids and the hydraulic mechanism they controlled. The outboard manufacturers came up with a Type C oil for those gearcases which is probably about a 5w20 to replace the usual hypoid oil and it works just fine.
    I also replaced gearbox and differential oil with ATF in a mini-stock Ford Capri race car (much to the owners horror) strictly as a horsepower saver and never had a problem...we won quite a few races as well!!!
"GM speicifies ....5W30 lubricant, which no one else has available as equivelent. ZF now says to use Castrol TWS 10W60.
These guys say say they analyzed the  full synthetic 10W60 and the "60" got torn up ~ 40 pretty quick (100 miles) and by 10,000 miles was in the 30s. And was so full of suspended bronze they recommend that as the change interval
http://www.zfdoc.com/faq.htm
At 100 C here some viscosities (in Cst) off the Internet-
ATF Dex III = 8
5W30        = 11
10W-30      = 11
10E-40      = 15
10W-50      = 19
did not find what "60" is like
Tmoose
Thanks for your reply regarding ZF6 lubricant.....The question still remains as to alternate lubricants...for example what about MobilOne in 5W30 vs the GM5W30 special lub or what about Mobil1 in 15W50 vs the Castrol 10W60
Seems to be issues regarding viscosity, change intervals, and additives(type of oil).....
I am not a lubricant engineer, but more interested as a Corvette owner as to proper lubricant for my transmission.
Seems to me there should be a basis as to which is correct..
It seems like ZF has decided that the CAstrol IS the right one.  I generally stick with manufacturer's recommendations. I figure they at least get to see a lot of the broken ones.
According to this - Around 1998 ZF, not GM, was rebuilding them. The following is from some archived message board that Google found in 14 seconds.  www.5speeds.com/archive/27.html
Sounded pertinent, but maybe too old.
> .....now seeing alot of broken 6 speeds and problems in 5 > year and older vettes. There are NO SERVICE PARTS offered > from GM for these transmissions. There never was. I > personally will never purchase any car from any company >that doesn't offer service parts for assemblies such as >engine or transmissions. GM just discontinued service >parts for the 4+3 overdrive and we are busy making alot of >these components. The current 6 speed repair proceduce is >the unit is removed and validated as a Corvette 6 speed >then boxed and shipped to ZF North America. Minimum cost >to inspect the unit is $500 plus freight. Average repair >costs are $2500.00.
Specifically re: Mobil One - here's something from the Yahoo Grandsport group back in August 2003
http://autos.groups.yahoo.com/group/grandsport/message/...
There is a reference from ZFdoc. Here's a piece of it.
> I don't know why or where anyone is using Mobile-l
> in these transmissions. Do you have any idea where
> the suggestion originated from? I'm curious to know.
> 4 out of 4 units that I rebuilt which had Mobile-1 in them had
> signs of galling on the synchronizers.
Later he mentions several other lubes.  I guess those are or were approved, whether by him or GM.  Mobil 1 is good stuff.  I could only guess why it would cause/allow a problem, when when some conventional 5W-30 works OK for 10k miles.
> The factory fill 5W-30 (GM P/N 1052931) is good for 10K mile
> intervals.
> Redline MTL is good for 20K mile intervals between changes.
> Castrol RS 10W-60 (BMW P/N 07 51 0 009 420) is good for 10K mile
> intervals.
> Even though the Castrol has to be changed twice as often as the MTL,
> I still prefer it's performance above the rest.
Have you been here?
http://www.zfdoc.com/techinfo.htm
He has a drill he recommends as practice for "power shifting" a ZF equipped Corvette.  Just the kind of thing I would have practiced every day in high school, undoubtably to the cruel enjoyment of my fellow students.
I am familiar with www.zfdoc.com
What is there that is so different about the ZF6 that it requires such a special lubricant???
The Castrol product is only available at BMW dealers at about $9 per quart.
My Corvette at just a little over 30K miles still has the factory fill. Just trying to get a better basis for selecting the refill. Do I believe GM or ZF or ????
I did not find a recent reference to GM's spec on line.
What do they say now?  I'm more than half expecting they'll go along with the ZF recommendation.
According to ZF DOc you're way overdue for an oil change no matter which one of his referenced oils you're using.
I think its curious ZFDoc says the oil change limiting factor is suspended bronze particles, and also reported the Mobil-1 damage is synchronizer galling (maybe the steel cones, not specifically the bronze synchro rings).
There are not many bronze alloys I consider my friend.
here is a good example of what I was trying to point out in my post above....the ZF 6 speed.
Besides contacting ZF directly...(708)634-3500 you can contact Mike Weinberg at Rockland Standard gear Inc in Sloatsberg, NY...or Callaway in Connecticut. These people will tell you that you must use GM 1052931 or Castrol RS10w60. both are real authorities on the S6-40.
idano
Perhaps I am being too stubborn, but I understand what they are saying, I just don't understand why.
What is there about a ZF6 that it requires such a "unique" lubricant??
Further on what basis would I choose between Castrol vs the GM fill? Viscosity??
Royalpurple claims to have suitable product but none of the other lubricant manufacturers offer a suitable product.
http://www.royalpurple.com/techa/tranxref.html
Check this chart for 1992-6 Corvettes.
"Is bronze unique to the ZF6??"
Every synchro ring I've seen has looked like bronze.
That's a few Saginaws and Muncies from 60s/70s, and early 80s Ford 4spd OD.
There's bronze, and then there's bronze.
I think ZFDoc referred to the ZF synchro's as some sintered bronze alloy, and claimed that was intentional to get porosity.
For years machine design type mags have blipped on "pressed metal" technology as (finally) suitable for a variety of high strength parts, and I think some modern passenger car engines have used connecting rods made via PM.  The advantages usually cited are generating near-net shape (allows less machining) using cheaper equipment, and sometimes interesting material recipes.  Until everybody embraces porous synchros I will suspect any porosity is a byproduct of the process, not a cherished property. Modern pressed metal brags how NON-porous it is.
I used to see t-5 after t-5 out of Mustangs that got the "Jiffy Lube" treatment. If you havent' had the experience: Drain out the ATF, install gear oil send the car down the road. It basically made them impossible to shift, I would drain them out, tear out the input retainer and inspect/replace the blocker (they used fiber material..explains why they use ATF) if it was toasted. Fill with regular ATF give it back to them. I would have them drive it for a week drain it and refill with Redline MTL, thats what we used and had good luck with it. I think its is similar to Royals Syncromax. I feel the synthetics are the only why to go.
First of all thank you all guys i'm new here.
Could anyone tell me something about Ford specification ESD-M2C186-A? is this ATF?
Ford recomends this for manual gearbox mtx75 in my car owners manual (ford focus diesel year 2000), but searchin the Ford Technical Information System Spanish edition, they recomend M2C200-C wich is quite different i think.
Any way is hard to find some ESD-M2C186-A fluid here and i don`t know wich substitute will be better, an atf or a regular gear lub.
i didnt read all responses but i have used ATF in the past in nissan gear boxes and it doesnt last too long. i had a lot of trouble with roller bearings freezing up and syncros smoothing and not working well.
Hi bigtom !
I'm interested what series nissan, and what is the factory spec'd lube?
I have Lada 110 (something like new Samara)and i use 80w in my manual gearbox. My gearbox is noisy in 1st, 2nd, and 3thrd gear but only in low rpm from 1200-1800rpm.About 1900rpm the noise completly disapier.Now i have 47000 kilometers but I have this problem from start!
I tried with 80w-90 and 90w but then the noise is worst.
Gearbox capacity is 3.3 lit, so it's robust.
Can I use atf dexron III?
If not, tell me some better advice?
Sorry if I done some mistake in english!
Thanks!!
Borq Warner recommends either ATF or 75w90 in their T5 manual transmission.  Normally, they say to use ATF, but if bearing noise is excessive or temperature are extremely high, use gear oil.  If the transmission is hard to shift, they recommend ATF.
I have the perfect solution to cars that are hard to shift
Double clutch your shifts and you'll never sweat your synchro's again.
(now if I could just get the hang of that heal toe downshift manuver while cornering)
I've got crunchy gears in upshift and not in downshift, and double clutching doesnt make the slightest bit of difference. Wonder if the old ATF will work wonders...Toyota specifically say not, despite other boxes rolling off the production line at the same time being AFT filled.
James
asfd56:
From the spec for Ford's ESD-M2C186-A:
"FLUID, AUTOMATIC TRANSMISSION, FRICTION MODIFIED,
FOR MANUAL TRANSMISSION USE-USE WSD-M2C200-C"
There you are;
 - R
Thanks Rob.  Since I have been using ATF in various manual gearboxes in race cars (one street car) since 1967 or so, some years before Ford Tech wrote that spec., does that put me somewhat ahead of the curve?  Just lucky?
Just kidding, as I learned that trick from someone else.  There are still "tricks" that are being used in racing today that are in the classification of "black arts" ,as using ATF in manual gearboxes was in the '60's.
I talk about it now but, I never even hinted at it while I was still racing.  I even have a few new ideas in my current vintage racer that I am not talking about.  I get older but I still love to experiment.  Some ideas work, some  don't but, as I said before, "nothing ventured, nothing gained".  Sorry for the cliche (I love them so).
Rod
there are some trans that for long term use can't handle atf
 the reson is the gears faces wear out because they assume a heavier oil also the bearings desinged for 80-90 don't last as long if run with atf. but it cherainly isn't instant death in most trans.
the opposite is also true. many boxes that take atf would come apart at the seams with somthing like 90-140 synthetic because the fluid doesn't flow well enough to adequitly lubricate that design.
some trans come with heavier fluid in them just to keep nvh guys happy and run perfectly with atf.
If I was racing i would try atf in the gear box and diff just change the fluid often and see how it works(alot of the new front wheel drives use atf for the diff)
Carnage, I'll go along with all that you said except using ATF in rearends (in general).
If you dig through all the posts I have made on this subject over the last three years you will find that I experimented on that very thing in the mid 60's.  It falls into the catagory of "not so hot an idea".  Perhaps my downfall was the ATF in the 1950's drag car's "BEVEL GEARS" (from an early Cadillac, I think, maybe a Buick as my '37 had bevel gears).
It was only when I tried it in a 64 HyPo Fairlane with a 9"  hypoid gearset that trouble set in.  Only lasted a few days and began to make noise that, eventually sounded like a  police siren!!!I picked up a used third member from Bobby Unser's wrecking yard and did like I was told, 90 wt.
My Mini Cooper vintage racer uses engine oil (Mobil 1 15W-50) for all the geartrain as well as the engine.  If I had to guess, as I am not a front wheel drive authority, I would say ATF works okay because of the final drive gear design.  Most likely bevel (straight cut) gears.
Rod
