Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
  • Turn Off Ad Banners
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...I frequent other newsgroups, too, and am MOST IMPRESSED with the lack of smart a-- and presence of genuine desire to help anyone of any skill level..."
Geography
turbo86 (Electrical)
1 Sep 03 9:28
   I would like to construct a wideband o2 sensor using a Bosch LSU4 sensor. I have a front sensor from a VW 1.8 engine ( about US$40.00 ). I understand that there are some Bosch support IC's for this application, part numbers CJ110 and CJ125. Does anyone know where I could purchase these parts and their data sheets?
   Also, the only technical info I have for this sensor is the 22 page Bosch (english)document dated 25.1.99  . I would appreciate any other tech info that you could point me to.
-Dana
Flowczar (Automotive)
1 Sep 03 11:09
Dana,
It really depends on how wide a range you want to measure and the level of accuracy you require.  I have found that sensor to be very inaccurate below 13.5 A/F and above 15.1 A/F for gasoline.  These limitations of that sensor may not be what you want, or can live with.  There are several sources for wideband meters, in no particular order...Bosch, Motec, Lambdaboy, FJO Enterprises, Horiba.
I have not seen any more recent data on the LSU4 than what you have.
CDC (Automotive)
9 Sep 03 15:33
I suppose the supporting hardware was bad in your case. Dynojet uses the LSU4 sensor, they work excellent in the area you have to work, from 10:1 to 28:1. Use it everyday to performance tune cars. I am not an electronic engineer so can't tell you how to make the supporting hardware but the sensor is good. There is a lot involved in making good supporting hardware, look at the complete datasheet on http://wbo2.com/lsu/Y258K01005e03mar21eng.pdf. Since there is no point running a gasoline engine richer than 11:1 these sensors are good for measuring lambda for these as well as diesel engines, which can run a lot leaner.
Tell me where you buy them for $40 and will order a bunch...
Hope this helps
9 Sep 03 15:54
Walk up to the parts department window of your local VW dealer and ask for a 021-906-262-B. Should be about $40.
CDC (Automotive)
9 Sep 03 17:11
Thanks, will try that, buy them now at $120 from the GM dealer...
andyv8 (Automotive)
12 Sep 03 12:01
A bit off-topic, but does anyone have an ETAS LA3 meter they would sell me.....
Andy
rjhco (Automotive)
29 Sep 03 15:02
There are several wide band O2 contoller boards available.  Tech Edge has a DIY kit.  It is their version 2.0.  Also, check out Innovate! Technology, Inc.  These boards are about $350 made up.  The TE kit is less.Best regards. Jim
CDC (Automotive)
2 Oct 03 15:07
Checked the price with the VW dealer, 154 Euros(!). Saw the best price on the net in the USA for $28.99 (!) What a rip-off.  Unfortunately it isn't worth buying it there if you only need 2 or so.
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Automotive electrical & sensor engineering Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=67
DESCRIPTION: Automotive electrical & sensor engineering technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
