industrial voltage
industrial voltage
industrial voltage
We are a small spanish companyl. We are selling our first machine and need to know about the electrical standards in the States. As we use 380 V 3 phases + neutral + ground. Which are the requirements in Usa.
RE: industrial voltage
3phase 208v+neural+ ground(equipment ground), 3 ph 208v+ground and 3phase 230v+ ground. On Industrial or large commerical installations 480v+neu+ground and 480+ground. All 60 hz.
What of need to know is what market you will target for your equipment for. Then find out what power your clients use.
Your equipment also needs to be capable the variations that are realized on the industrial side, that is +/-10% for voltage.
