oil flow rate on the main bearing
Could someone help me to understand how to calculate oil flow rate on the main bearing of the crank-shaft of a car?
Thank you
Best regards
Manini
Thank you
Best regards
Manini
RE: oil flow rate on the main bearing
Q = 0.00003 to 0.00005 D x B.
Not sure if this isn't applicable to bearings in a car.
Very kind
Manini
