Relationship between differential pressure and flow
What formula is used to calculate flow using differential pressure in pipes? Are any other variables taken into consideration?
                    Thanks.
RE: Relationship between differential pressure and flow
Be a bit ealborate
Darcy's equations is usually used.  There are other variables:
viscosity, density, pipe roughness, pipe diameter, etc.
maybe you should take a class in fundamental fluid dynamics?
Best regards Morten
